Will all the linkages and kickdown stuff bolt right up to this,or am I gonna have to tweak stuff here and there?
Is your car a column shift or console/floor.
Column shifts require the tabs on the bell housing (drives side) floor shift cars require the tabs that are on the tail shaft housing just below the speedo gear hole.
