Also you may want to check to make sure old pilot bushing isn't still on the output shaft of the tranny. Did you replace the pilot bushing ? Do you remember seeing the old one ? I have seen that a couple times. And it won't look real obvious. Tap it with a punch, if it marks, I'd say the bushing is still on the shaft. Good luck.
