The AMD trunk floor has been test fitted in my Charger 500 with great results & no problems so far. Waiting on AMD repro rear valance and trunk floor extensions for final fit-check.
BTW, the drip-trough was completely cut through by Creative Industries during their modification of the car to a Charger 500 "Aero Car", so with the quarter panels removed the drip-trough is two seperate pieces... The part being bent to pivot the taillight panel down like a tail gate is only the rear valance which is totally rusted out and will be replaced when the AMD repro is available. Pivoting the taillight panel back down to its correct location allows for a better test fitting of the quarter panels & trunk floor than if it was totally removed (which WILL occur later). No parts have been cut or bent that will remain with the car...
XS
