Hey Bob, thanks for chiming in!
I'm with ya' on Diamonds; they have earned a pretty good rep.
I believe that the pistons Brandon at the Source sells are KB forgings; I think they're in the mid four hundreds range for the same stuff at the big online stores.
Ya' know, I don't think I stressed this enough, but this is a very bucks-down kind of build (we're using all stock shortblock, with the exception of cam, rod bolts, and pistons.
Jon was originally just going to freshen the engine as a stocker w/ a cam, but the bores were just a little tired for that.
So, I'm looking for options to cut some weight off the pistons and help the rest of the lower end live easier.
BTTT...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
