Critical speed is the deciding factor in drive shaft material selection. Aluminum increases your critical speed rating, there is no real performance advantage to it other then raising the critical speed rating.Call Mark Williams, PST etc and give them your drive shaft length and maximum RPM at the stripe and see what they say.
