Seems I've heard something about using a special antifreeze or using some kind of additive with your antifreeze to fight corrosion of aluminum parts in your cooling system mainly the radiator.
Is there something special to use, or am I OK with regular antifreeze? Just installed a new aluminum radiator and I want it to last.
Thanks,
Scott
Modern green (and any color) antifreeze has properties to handle aluminum. Since you are adding a lot of fresh surface area you might want to add a supplemental coolant additive like Justice Brothers Radiator protectant. Just extra precaution.
