fyi eddie 2 step rods/jets/springs will work in an oe AVS plus epoxy the metering rod caps full to make them flat like the AFB/eddie ones and as I'm sure you know oe AVS 3 step strip kits are pretty much non existant and since all oe AVS's were emission calibrated carbs which can benefit from rejetting.
