Does anyone out there know how long a stock dip stick should be for a mid 70's 440, with stock pan, i believe it is a 6qt, i took off a deep sump moroso pan because it hung down too low for the car, i would like to use the same dip stick but when i stick it in it actually hits the bottom of the pan,and i know the "full" mark has to be off as well.
