All cars of the era use some sort of insulating between frame and body. While the roads are much smoother, the speeds are higher. The frame will flex some, so I'd think that there would be some creaking.
I'd also worry about trapped stuff leading to rust. I'd go with a rubber or impregnated rub strips.
