Yeh i have tried different setting from softer to the hardest.Balancing the tires I think is a bit of a grey area, because I thought that when you leave the line the tire is so wrinkled that it wouldnt matter on balancing, because if its balanced it forsure isnt when leaving the line.But maybe it could be part of the problem?
I know balance sure helps down track(at least it does
on my car). Sure balance doesnt matter at the line,
your not turning them fast enough to see it...
By the way I use the QA-1 singles but havent seen
your issues
