Did you remove the plate for any reason? There is a gasket (or an inner and outer gasket) behind it. I wouldn't think you could damage it, but you might have a big scratch across the filter gasket sealing area. I have a friend that could bend it by overtightening the filter, but he was able to break off the stud on a trailer hitch ball.
