i had a similar problem, but it turned out to be cracked rubber fuel lines and a steel vent line loose in the tank. i noticed the leak after i changed the sending unit. turns out gas was running from the vent line down the tank and pooling and dripping from the sending unit.
just something you might check.....
shane
