The air quality up here in Ohio isnt too bad, its pretty mild and not too humid.
Your setup had almost a point more compression, and those SR's are a way better head than what i run. But still i agree with you that i should be close to 130 mph with this setup. I really think it could use a gear change and maybe some more timing. As of right now it will run 113 mph at limiter in 3rd and it will go through the 1/8 mile in third at only 102 so a steeper gear may do the trick. And also i only have the timing at 30 degrees total because i didnt know how far the 110 would allow for.
But i really appreciate all the info so keep it coming.
