After you bloody up your fingers and destroy the first one you get the hang of ir quick! I had nightmares for weeks after installing my first set. Yeah, how do you get them out???
some pistons have a machined groove to help get a real thin pick under the tangs on the end of the spirolocs, some don't If yours don't you have to use the pick under the edge of the tang to lift them up high enough and try to get another pick or thin screwdriver blade unde it to help walk them out It takes practice, just like putting them in
