The A body manifolds are the ones. A van doesn't have to clear a steering column.
I'd have the manifolds on before building the mounts.
Here's a pic of the mounts in my 40 Coupe.
If you do something similar, remember that the rubber will compress. Weld them on a sixteenth to an eighth of an inch higher....
