Hey Alky guys, do you use your lean out valve for everything but the burn out and run?
do you start the motor with the lean out open?
My Terminator uses a shut off valve to lean it out, but i am unsure if i should use it while starting?
How high do you take the idle up when you are trying to put some heat in the motor??
Thanks,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
