It says on there site that it is a speed demon if it has the red adjustable cap on the vacume secondaries, this one does. Aparently this is a little older of a model even though it looks brand new because it has straight leg secondarie boosters and down leg primaries even though the only ones they have listed have anulars and down legs but no straight legs It has the 7 on the casting for the main body size
This is a very rediculous way of gettin part numbers
Red cap could be added on. No speed demon to my knowledge comes with one inlet and a rod feeding the bowl. Only the road demon JR.
To id the carb there should be numbers stamped on the choke horn.
