I'm currently collecting parts to put a 470 together next spring. I plan on building a low deck with 6.700 rods a 1.30 ch piston and a 3.915 stroke crank. This should give me a little room to have the block decked and get close to a zero deck. I'm going to build mine as close as I can to Andy Fs' 550hp build except with a hydraulic roller. Hope this helps a bit.
Mine is similar to this,
Low deck, 6.700 rods, 1.32 ch and 3.900 stroke and Bulldogs heads.
According to MM compression is 10.02:1
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
