Re: Oil pressure , need help.
[Re: galen]
#480499
09/26/09 10:57 PM
09/26/09 10:57 PM
Dan it drops back 3500 or higher, no load.
is this a recent build? you can try replacing the spring and relief valve, but your symptoms are normally associated with vey loose bearing clearances bleeding off a high volume of oil. you might also test the rocker oiling by stepping down to .035 restrictors. use a drill to prime it and see if you have excessive leakage up there.
Cab, i've done dyno testing regarding oil pressure and high/ low volume pumps. the largest differential i ever saw was about 1 horsepower, and that was going all the way down to 45 psi. we documented the tests very carefully matching oil and water temps on each successive pull. give it some thought, a 1/2 HP drill will spin the pump to max pressure and over relief. a 3/4 HP drill will spin it slightly faster, but no difference in pressure or volume is achieved.
Entire Thread
galen
09/27/09 12:40 AM
Old School
09/27/09 01:49 AM
MR_P_BODY
09/27/09 02:04 AM
09/27/09 02:22 AM
galen
09/27/09 02:33 AM
Cab_Burge
09/27/09 02:50 AM
09/27/09 02:57 AM
galen
09/27/09 03:17 AM
09/27/09 03:34 AM
galen
09/27/09 03:41 AM
09/27/09 04:05 AM
galen
09/27/09 03:37 AM
