Thanks for the link Dodgem / dodgeboy8. :-)
For the middle 3 I am definitely going with 4 bolt angle caps. I found someone that had a full set of all 5 caps so I bought them from him.
if that's a factory block, i wouldn't recommend doing that. all your doing is creating another stress riser from where the bolt holes break through and from the cut threads you'll be putting in there.
