super street
Hawaii
sounds like it,,,,,,,but I've owned the truck around 4 years now and I never had distributor out,,,,,and this truck was running solid the whole time,,,,even 2 weeks ago trying to start it,,,,it turned over once and ran,,,shut it down and it never restarted,,,,,could it have been running 180 out????hmmmmmmmmmm,,,I think we did try to time it with a light and couldnt get it dialed in,,,,so,,,,now I've got the camshaft gear mark at the bottom,,,then i pulled it and turned the crank one turn to #1 tdc,,,then i pulled the dist. up and turned it 180 to #1,,,,now everything is lining up,,,,now if my bro-in-law ever shows up with a gear puller,,,I can put it back together
did I actually do anything here,,,,or did i just spin the distributor 180 been buggin me all week,,,back down to timing chain,,,,gonna pull valve covers today and see if everything is movin up top,,,,,man this sucks,,,,,this wasnt in the plan
