I had phenoilc spacers on my B1 motor. The only issue I had was the manifold takes some time to get enough heat in it to put the engine against the 2-step.
MRMOPAR570,
The B1 and Indy heads have different angles on the mounting flanges so they will not interchange without adapters. IIRC Best Machine makes adapters for this.
Bob
