Do you know where the motor makes peak HP yet? It looks like it is still climbing at the RPM you stop on the dyno sheet I have seen a short( less than four inch) stroke motor almost stop making HP increase at 6500 rpm and then take another breath 400 rpm later and make peak power at 7800 RPM and gain almost 50 HP
