Guys,
I am finally getting my car restored and it will soon be time to pick out the rims/tires to go on my Charger. I DO NOT want to use the stock spoke hubcaps!
It is a 1973 Charger with an 8 3/4" rear. Can you recommend a good rim size with wider-than-stock tires but no scrub? Im thinking 15" or 16" max as far a diameter.
Also I am not very knowledgeable about this but does anyone know what backspacing, offset, etc I will need? The car/axel is stock except for a SSBC disk conversion which fits fine under the stock rims...
Any thought's on which specific rim you guys like? Any input is appreciated!
