You said stock converter so it must be an automatic. You won't go wrong with a Comp 268 XE. The MP 272 cam would also be a good choice. Or call Jim Dowell at Racer Brown for a custom shaft. Hughes Engines has a nice line of cams, but they tend to be high lift relative to duration so checking clearances becomes even more important than usual.
