Before you change the springs buy a set of good drag tires As far as a pinion snubber don't waste your time or money, a good set of springs will never let the snubber hit the floor The springs you have should work well with a good set of tires as long as the rear shocks are not topping out Did you clamp the front half or all of the springs?
