I have the milodon pan with the static remote pickup and the Muscle Motors pump cover. This car is an original 69 Cuda 440 car so the k-member supports for the steering box require the line to the pan to go around the k-member as the pictures show.
I have primed the oil pump three times by breaking the connection at the bottom of the curved tube and shooting lubriplate into the suction side of the pump and then running the pump with a drill. It primes right away and I ram the pump for about 5 minutes. I waited for 1 minute, started the drill, pressure ok, then 5 minutes, started the drill, pressure ok. Then after 30 minutes and checked prime again, and no pressure.
Any ideas would be greatly appreciated.
