There's at least an inch difference between a post and hardtop door glass with the post being shorter as in the photos. You can deffinately see the bottom of the door glass difference if you still have the door panels off.
I used the original door glass, so I know it is correct. It's like the mounting holes in the 1/4 glass are in the wrong place. The 1/4 glass is sitting about an 1" farther back than other side.
