If you are running a fuel cell I don't think there's an issue as to whether you mount the box on the outer or inner wall of the stock frame rail. But if you are running a stock tank, I think you need to mount the box so its flush with the inner wall of the frame rail, otherwise you may have clearance issues between the leaf spring and the sides of the gas tank.
