Re: two step
[Re: MikeyT]
#464236
09/09/09 08:33 PM
09/09/09 08:33 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
What is a 2 step?
Mike
a type of country dance...
a two step holds the RPM of the car at a pre determined rpm while on the starting line, (the throttle is floored, the rpm stays at 3500 (for example), let go of the button and the 3500 limit goes away and now you have your rev limiter. (two settings, two step) there are more technical and more involved explinations that i'm sure people will post, and repost and then verify as being correct,
