Get one of these at Summit Racing for $7.88
http://www.summitracing.com/parts/DCC-4286800/?image=large
Mark where the rotor is pointing so you can put it back in the same location. Pull the dist and drive under it.
Insert the tool hooked to a drill that runs in the direction the dist usually turns.
Run the drill in the correct direction while cranking the engine with the starter.
When you see oil from the rockers you're done. I don't pull the valve covers, just look through the oil fill hole.
