I had the same issue. I went with a different rack and pinion where the shaft was horizontal with the ground and the steering linkage under the oil pump.
I already bought my rack but could you send me some info like pics and part #s? Thanks.
Maybe I could return the rack for a different one.
First rack was a Wilwood. The shaft for the column came out with an up and to the left angle and went directly into the oil pump.
New rack is a stilletto. The steering shaft is horizontal with the ground and perpendicular to the rack.
Pic with the motor out
