Quote: heres the pieces to put inside the indy crossram,they are made of epoxy sleeved with longer bolts. they are going on my 500 ci motor in my 63 plymouth, this should get me right where i wanna be.
And here all along I thought you were going to tell us all to join Jenny Craig I know I could lose a few lbs but not enough to gain .15 so, are you going to do a back to back test on these at the track to verify the .15 gain?
Russ
already have Russ on the 65 dodge, its a full .15 i had to get the other set before i posted, they've just made another run of them.
