OK, here is a shot of the door as it is today. You can see the upper door panel is white. I think that should be blue, medium blue or bahama blue or light blue poly (this is what is on the chips sheet). I've seen armrests that are blue or white. Clueless on which is correct.8
The chips sheet also says low gloss finish Bahama blue poly for convertible upper windshield only? Where is that? For that matter, whats a garnish moulding?
