Do they adjust farther than 30/70 ? Seems like I need an even slower shock than that.
Things are pretty violent with a Stick! The shock load is pretty severe.
Have you switch the rear springs yet? If not maybe that is the next thing to do instead of doing the shocks first Why replace the rear shocks twice, if you find that the springs are needed also The rear springs should do most of the work and the rear shocks are for fine tuning, IMO
