Tire pressure at that time was 18 lbs M/T street radials. After I lowered the rear I got the 1.44 60 ft . I believe on that run it was around 1.51.
When you say "lowered" are you talking tire pressure
or you lowered the rear of the car... if you can lower
the rear of the car, that would help... but what is
the tire pressure now... have you tried even lower yet
