went out to a T&T on Friday night to try a few things/practice prior to the Nationals.
first pass,launched and thought i had axle tramp - no such luck .
drove home,pulled the centre not much left of the spider gears.crown and pinion were ok
dana is not an option where i live,cost,but i can get a true trac.anyone used one thoughts ? to be used in a street/strip car.3710lbs,mid/low 11's
thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
