The Pro-Gear is a nice piece but, key-ways in cam gear can be confusing.
They are indexed in camshaft degrees as opposed to crankshaft degrees.
i.e. If you need to advance cam 2º you only move it 1º on the cam gear.
I've used the off-set keys to dial them in, even when using multi-keyed gears.
