Quote: jet extentions wont help with sideways carbs.
A set of 90% bent tubes would so the ends are at the rear of the carb(what is the rear now)... might be able to use a short piece of fuel hose to connect them to the jets.... I'd do all of the jets to make sure they are all getting fuel. This should work for a test and if it corrects the problem then I'd make up something that would be a little more permanent. Also the comment of being slower in high gear... it could be a air issue... put a air pan on first that may knock out some of the hot air thats up in the cowl(thats where its trying to escape to)
