A 400 block is taller than a BB Chevy block so there is more room in a Mopar for a longer rod and a taller piston.
A 454 Chevy or even a 502 BB Chevy can easily handle any durability test that the OEM's use so there isn't any reason that a 500 inch low deck Mopar can't also. You just need to build it correctly.
