I would think you would place the car on jack stands and use a floor jack under the rear end to adjust it to the location you want .
Yep... thats all I would do
EDIT
re adjust the pinion angle also
That is the way I do it, let the floor jack down so it is barely holding the rear end up to have a tiny bit of weight on the shocks, remove the bolts and either raise or lower the jack to the holes you want to us
