Chrysler used to measure duration at .006" lift, and if you go back far enough they measured the the intire lobe from start of the ramp to ramp. That's where you get the large numbers.
A common duration figure, @.050" lift, for a stock eliminator cam starts at about 260 degrees.
These cams are extremely peaky; they work in a very narrow rpm band.
