Talk to Cass at DoctorDiff.com and he'll set you up. His rear disc system is the best one on the market. I know that sounds odd because he runs a small shop compared to SSBC, MP Brakes, Baer, etc but he did the proper engineering and some of the big guys didn't. His setup works with the tapered roller bearings for example and it bolts on without a bunch of clearance issues.
I have his 11.7" rear kit on the 8.75" in my 66 Coronet. He can supply the emergency brake cables also, which can be a pain in the azz to get right -
