It is my understanding that many vendors still sell "sending units" (designed for GM cars) for MOPARS use & the ohms output is all wrong for OEM Mopar gauges.
Do a search on here, others have had this problem & found proper source. I have this problem also, at a full tank my gauge only reads a little over half full.
Edit: MOPARTS member "Mopar Grandpa" reported senders from Inline Tube worked with zero problems; http://www.inlinetube.com/
John
