Just line it up with the orig frame on the other side of the crossmember. If you are using a wire feed just split the difference on both sides an dleave an 1/8th inch gap on each side - easy to fill. Then go in with a good hot stick weld (or wire)to get some good penetration!!!!!!
Hell B!tch Racing Co.
