I installed a Pertronix plug and play distribator and a Pertronix epoxy filled coil in my 440.. Removed the wire in the ballast resister and soldered in a 10 gauge straight wire..
My understanding in doing this is my system needed 12 volts and the new coil is designed for 12 volts.. easy....
