So here is my combo:
74 Cuda, 360 727 (stock converter), 3.23 gears, 27.5 in tall tires.
The engine is a around 9 - 1 compression.
Torker II intake,
Torker plus cam (@.050 Int dur. 222 , Ex dur. 234 Lift Int .447 Ex .450 Intake Centre line 107 Ex centerline 116)
750 Holly vac seconday carb.
My initial timing is set to 14 degrees, car starts runs and idles ok (rumbles away at at 750 rpm with no problem). No detonation that I can here under aceleration.
The timing will advance all the way to 55 degrees as you rev it up (not sure if that is it, or at what RPM it stops advancing.)
The car does not bog at all from a dead stop when you mash the go pedel. However, the car will not spin the tires from a dead stop, and it does not accelerate the way I would like / think it should.
So my question is, how do I fix it / make it better?
I am open to hearing all options. Lets start with tuning options, and go from there.
Thanks,
Jason
