Thanks guys I will definately start with the basics before I start spending cash. the carb is lots better than the old one I took off. Engine is much more reaponsive even sounds "crisp". Apparently the old carb way a bit on the lean side as my engine temps have dropped 15 to 20 degrees even in todays 90 degree heat.
