You may run into another problem- are the axles for A or B body brakes? The width is different and B bodys add 1" to the overall width of the rear.
I installed one Strange axle on the passenger side and measured from the brake backing plate to the lug flange on the axle and did the same on the driver side which still has the small bolt axle in place. The measurement is the same.
