I decided to check the oil level in my Charleis oil pan, which I bought off of a member on here and I didn't have a part number to work woith to ask Charlie on how much it should have. He did say that most of his oil pans like this one, aluminmum SS style with a kick out and a tube for the steering cross bar, usually hold 8 to 10 quarts depanding on the car and depth of the sump. I will post the first picture on here, the amount of oil is written on the rear of the pan above the rear oil pan slosh baffle on the end of the oil pan 8 quarts if I remember correctly
I always use the cubic inches to figure the volume
when I make pans(231 cu in per gal) then when completed
fill them to check
